DIY: Ferrari 360 F1 System Bleeding
5 reading
425 views 29 replies 6 participants last post by  theflash32
#1 ·
Hopefully this helps others save some time or money knowing that you can do this in your own garage with some hand tools and patience and little bit of time.
#9 ·
Thank you!
Yep! Same for the F430. Release bearing hydraulic block on the side of the gearbox has the same weak point like the 360 even. Same filter in the solenoid block also.
I don’t know for sure if the Foxwell NT530 officially works on the F430 or not, or what test procedures it has as I haven’t tried it on one (yet).
#22 · (Edited)
On a 360 it is 213111 and 193540
I believe the same in 430 ...although only one is shown (193540) for f430
Thank you for posting the part number for the 430, I'll update my video and throw that in there in an effort to try to keep this info in one place for the next person that trips over it.
#21 · (Edited)
On sale 129.
Then buy a cheap tablet or if you have an Android phone you are set
It works on iPhone but it lacks some functionality
Here an example
#24 ·
I just checked Eurospares parts diagrams and you're absolutely right. They are the same part number for the inlet filter on both the 360/430.
When I picked up the high pressure filter for the 360 at an independent shop here locally, I had a good chat with the Ferrari master tech/owner who happens to be a good friend (oddly enough he used to work at the same Ferrari dealer I did, but many many years later on!).
Anyhow, he mentioned the same high pressure filter is in the 360/430. There is also a high pressure filter in the 575/599/612 apparently too as well. I personally haven't ever replaced one on any of those models, because most owners hardly drove the vehicles or put miles on them! Also I didn't even know it was there as the parts diagrams don't even list it (aside from the 360). So take that with a grain of salt about the later models until someone can get in there and physically confirm it.
I trust my friend, but i didn't ask if the part number from the 360 was the same one used beyond the 430 into the 575/599/612. It would make sense that it COULD be, simply because it looks like on the parts diagram for those that the same style fitting from the solenoid block is used to adapt into the high pressure line, but that could also be coincidence.
#26 ·
Absolutely. I shot that video off the cuff and left that out unfortunately and its just as important as the other filters. Almost more so because if its plugged then everything downstream works much harder. If i remember right its just a strainer that isn't able to pulled out. You may have to refresh my memory. Last time i touched one of these was 2009-2010 aside from recently on my own 360.
#28 ·
Resevoir looks VERY similar if not almost the same to whats used on a few BMW models (ZF Power steering fluid resevoir, ect..) They work the same way with the integral filter. Wouldn't be surprised if its a variant or cross references over.
Either way, thank you for pointing that out in general! I obviously blew right past it 😆
I updated the video description to call out what i missed with the additional pump inlet filter part number just for reference as well.
