A change of pace this weekend. Reg asked is I could help him by converting his QV intake for efi, so here we go.
The first thing is knock-out the CIS junk
Haltech e11v2 brain,,it was top of the line 6yrs ago,,I have a Haltech wire harness and Im workin on that,,Cribbj got me on prius smart cops,they fit very snugly.the prius cops are $20 each,they are the same as a GS430 Lexus I serviced the other day,,,,the fit is really snug,,Nick F uses them on his personal Car w/ no bolt hold down.....,,No dizzys,no plug leads and Im making a cam sensor housing from CF,,lol,,Im digging for a 348 cam sensor housing.Thanks for your interest and input.
Doc, not to speak for Reg, but if you're content to run a waste spark system, no cam sensor is required. Waste spark will fire each cylinder on both compression and exhaust strokes, and it only requires 4 ignition outputs (for a V8 engine).
If you want to fire each cylinder only on compression stroke, then you'll need a cam sensor, and your ECU must have 8 ignition outputs (for a V8).
I would stick with the smart coils, less engine noise than an external ignitor, and if I recall haltech has either + or - signal to the ignition outputs which you will need a + signal for the smart coils. I've used in many cars dumb coils with external ignitors but from here on out plan on smart coils.That depends.....
If you want to keep/use the Prius smart coils, which have the ignitors onboard, you shouldn't need another box, as the Haltech should be able to put out a logic level signal to turn the ignitors on & off & spark the coil. This will result in a straight, inductive ignition, which should work fine, unless you're running alky, nitromethane, or boosting to 3-4 bar. You'll have a good, simple & reliable ignition.
Should you have any thoughts about going with an aftermarket CDI box (MSD, etc.), then you'll need to rethink using the Prius coils. "Smart" coils like these, which have the ignitors onboard, preclude the use of CDI ignition (CDI's don't use ignitors).
CDI ignitions need "dumb" coils without the ignitors, and although most CDI boxes work OK with most dumb coils, they work best with those that are specifically designed for CDI.
CrownDog,ck out COPs for 308,,Cribbj worked me thru the wiring,its simple,,Merry Christmas and Happy Holidays to All FerrariLifers.
Right. The ignitor is just a high current driver that can withstand a high voltage back EMF when the coil fires.Jack, the ignitor itself doesn't boost the voltage to 500, it's only a solid state switch. It's the CDI boxes that boost the voltage.
