My upper P/S hose has been weeping at the reservoir, and since I'm now finished with the projects in China and Algeria, and am working in my company’s headquarters, 10 minutes from my house, I decided to sort this pesky hose myself, and "while I was in there" go ahead and do the "major" plus a "few" other things:
• Change the P/S reservoir to one which has a 3rd connection for the front lift kit
• Repaint/powder coat the intake manifolds and cam covers
• Put a smaller drive pulley on the alternator to prepare it for increased electrical load
• Replace radiator fans with higher output versions and a new/better shroud
• Replace the radiator with a new higher capacity unit
• Reroute the A/C lines so they're not serving as skid plates for the car. Other 550 owners who have been under their cars and seen the A/C line routing will know what I mean
• Experiment with some different gasketing material and fasteners (as some of you know, my 550 and Ferraridriver's are the guinea pigs for the products that we develop as Maranello Skunkworks, so a "major" service is a perfect opportunity to dig in and see what else can be improved.)
Up ‘till now I've simply been taking things off the car/engine, and I've removed the P/S pump, reservoir & hoses, radiator & fans, intake manifold, cam covers, water pump, water manifolds & hoses, and the A/C compressor, hoses & condenser. (I think it's definitely time to stop taking things off, and actually begin the major 'cause I'm running out of space to stack stuff that has come out of the engine bay!)
I’m not really intending to do a step by step photo journal here, but will post pics and updates of interesting points as I encounter them.
Here's one of the throttle bodies after stripping the paint off, next to the other throttle body which is still painted. I've always liked the look of natural aluminum, so I'm thinking to keep the natural finish on these. The only downside of the natural finish is its tendency to oxidise over time, so perhaps a clear coat might not be a bad idea as long as it doesn’t yellow:
And here’s one of the underside of the manifold with paint still on it:
And after stripping:
I think the natural finish is a winner?
Unfortunately the top of the manifold and the cam covers haven’t stripped as cleanly as other pieces, so they’ll bear some more attention, and/or may require to be soda blasted before they’re recoated:
I also have a vexing little problem with the engine harness and am trying to come up with some ideas for it. The OEM wiring is sheathed in a high temperature fiberglass sleeving, which has a neoprene, silicone or other flexible outer covering. With heat & age, this outer covering is flaking off and looks unsightly. I initially thought of that Plasti Dip outfit and dabbing some of their product on it, but it’s only good for 200 degrees. Now I’ve located some silicone dip/paint and may give it a try:
