Hi all, I have been using the 360 for a few months now and my car only has 7,000KM on it. I had an experience with a gear warning light which the Ferrari dealer here said it is time to change the clutch.
My question is what are the signs or when do you know is the time to change it? Thank you in advance...
Is your 360 an F1 or manual ? If manual, can you feel it slipping under load. Easy way to tell is get on an open road, drop it into 6th gear at 1500-2000 rpm and then mash the accelerator. If you can feel it slipping, then you need to replace the clutch.
