what brand antifreeze?
2493 Views 8 Replies 5 Participants Last post by  Pete04222
Hi, what kind of coolant should I refill my MD QV with? Does brand name make a difference as long as it's green??
Thanks y'all
1 - 9 of 9 Posts
doesn't really mather wich brand of antifreeze, just check for what tempurature it is intended and on how much water you need to add
btw, do you need antifreez in texas???
DJ,
a couple of days every winter the temperature drops below 40*F and I panic and check the antifreeze in my cars and spread some salt on the driveway 8)
that's about 4-5°C
mine, you are lucky then
at the moment if it TOPS 13°C here, then we are lucky, at the moment it's 0°C outside :eek:
Dj Dirk said:
that's about 4-5°C
:green: Sunny and 65 here and it never gets below 40 and from now until about November there will be almost no rain. 8)
so, andrew, didn't you said that you wanted to come over before the summer? are you sure now? because i'm affraid that you would freez to death :p :wink:
and besides, last summer i didn't found it that hot in SF or Monterey on most days, especially the mornings where usually cold :-?
Never too hot, never too cold. Just right.
Only advice would be to use a known premium brand (Castrol, Shell, Agip) and to get the concentration level right for you climate.
It's not just antifreeze, it is coolant. Not only does it lower the freezing point of water, it raises the boiling point. Water has a high capacity to hold and transfer heat, the coolant modifies the water to lower the freeze point and raise the boil point. 50/50 is the most effective mix.
Engine coolant contains anti-foaming agents, lubricates the water pump and contains corrosion inhibitors. It's these additives that deplete and dictate a flush and fill every 2 years.
As for the brand, go for the higher-end stuff. Make sure it says "protects aluminum" on it. Your higher end coolants will have less contaminants (abrasives) in it to help protect that expensive Ferrari water pump. The new Prestone extended life is good. And you should mix it with distilled water so you don't introduce any minerals into your cooling system.
1 - 9 of 9 Posts
