Calling V8 mechs!
I've started hearing a top-end noise at cold-startup that I need diagnosed. I can best describe it as an series of irregular (between 1 per sec and 5 per sec) sharpish taps coming from under the front cam cover (top "rocker" cover not side belt-cover). The motor is a 3.2 V8.
It seems to come from near the end closest to the belts. It sometimes takes a second or 2 to start (from cold), and usually only persists for 10 - 15 secs, but has gone longer. During this time the motor is only running at < 1500rpm. By the time the car is on the road (30 secs) the noise is gone, never to reappear until cold. Even a restart at the end of the day after sitting all day gives no sound. Oil pressure is straight up in <1 sec. No other problems. Car is driven v.regularly (2 hrs per week min).
A mech I know has said sticking valves, needs an engine drop to rectify (as you can't access the front head in-situ due to bulkhead proximity.
Do I hear other opinions? The noise is quite irregular in rythym as in tap-tap-tapatapatap-tap with varying gaps between, is definitely metallic and sharp, but not overly "heavy". Considering the motor is doing 20 revs/sec (10 revs/sec camshaft) at 1200rpm, there is no way the tapping is that fast. Maybe every 5th cycle or so.
Is it possible for the buckets/tappets to be sticky in their bores until warmed? Shim problem? If sticky valves, how can the valve "stick" with such monstrous springs forcing it shut? Esp as the guide & stem wear with age (increasing the gap between)?
Any thoughts apprec. I'm loath to drop the engine without more advice.
Thanks.
My guess is that it if it sounds like ball bearings in a blender... it might be the Air Conditioner compressor belt being loose. It is a common problem and goes away once the engine expands due to warming up. Of course feel free to have a mechanic verify.
The sound usually seems like it is coming from near the cam belts near the top of the engine. You could tighten the belt a small touch, i decided to remove the AC system in the car as it was fairly useless.
Yep, seems like it was the accessory belts after all. I could have sworn it was a definite metal-on-metal tapping, so there you are.
Thanks for the tip - nipped-up the AC and Alt belts a touch (Water pump belt seemed on-spec), cleaned-up the belt & pulley faces as far as possible, and the noise has gone. I've just invested in a can of Belt Dressing which I'll apply tomorrow, hopefully that will put the *engine-out* problem to bed.
belt
mu 89 was doing the same thing a while ago , it was the AC belt and the compressor bearings, i disconnected the compressor and belt, i also had an exhaust manifold leak that was making the same kind of sound, i thought it might be a valve out of adjustment as well, turns out it wasnt,i had the shop fix that as well on my major in 2010,Brett
