Dr. Bob. Suspension and brakes - we do what a customer wants and is prepared to pay for.
Drive train reinforcement is not needed.
Chassis number....umm, don't think the owner would like to give it out.
Senna21.
Please refer to the following for full details. There are no blow off valves! and the wastegate is plumbed back into the fabricated exhaust system (you can't use a stock exhaust or muffler.
Two Packages are offered as follows:
1) 575flywheel hp (355kW) at wheels (6-psi boost)
· Pre-programmed MoTeC ECU M800 with plug in loom adaptors (can be upgraded to include traction control, Lambda, logging and so forth).
· MoTeC loom and associated fuses.
· High-flow 4-spray fuel injectors.
· 2 x High-flow Garret GT roller bearing turbochargers.
· 45mm Turbosmart wastegate.
· 2 x custom high volume tube and fin intercoolers with cast tanks.
· Thermatic fans on each intercooler with On temperature of 28c and 22c Off via MoTeC switching.
· Custom large volume Air Cleaner box with low restriction K&N filter element mounted under bonnet vent and associated tubing, cast in aluminium in either polished or powder coated finish depending on customer’s requirements.
· Turbocharger exhaust manifolds 3mm stainless steel or cast (depending on application (depending on catalytic converter).
· Same with cast stainless steel wastegate plumbing.
· 2 x Cast aluminium pipe from inlet manifold to intercooler pipes.
· 4 x 76mm rubber ‘hump’ hoses (intercooler/inlet).
· 6 x 76mm silicon rubber hoses (turbocharger to intercooler and turbo to air cleaner plumbing).
· 20 x stainless steel hose clamps.
· 2 x aluminium weld on dash-10 sump fittings for turbo drain back hoses (depending on quantity we will cast a higher volume CNC machined sump with integral drain back holes).
· 2 x braided stainless steel turbo drain back hoses.
· 2 x braided stainless steel turbo feed hoses.
· 4 x braided stainless steel water feed and return hoses.
· All copper washers, banjo bolts, T-pieces, gaskets and hose clamps to suit above.
· High-flow dual inlet and twin outlet 3-inch in and out stainless steel muffler.
· CNC laser cut turbo-mounting bracket.
Indicative current buying price: AU$42,000 + shipping and insurance.
2) 650hp and 400 rwkw (9.5 psi boost)
As above plus:
· High volume package.
· Modified programming.
· Modified wastegate.
· High volume fuel pump.
Indicative current buying price: AU$47,000 + shipping and insurance.
For those who would like to know a little more about the company behind the product, please refer to the web sire:
www.nizpo.com.au.
