1 - 20 of 38 Posts
Thought you may be interested in seeing a recent twin turbo conversion by www.nizpro.com.au from the land downunder on an F355.
The engine is internally stock and at a very early stage of development (just completed - running out of injector - 7psi boost max) it's making a genuine 450 rear wheel horsepower.
I've attached a couple images for a look see.
Dr. Bob, sorry I hadn't replied earlier!
Yes, this is the first tt conversion of the F355 Ferrari, however Nizpro has performed numerous other TT conversions on various cars.
The results since that first post have changed a little in that now with larger injectors and 9.5psi boost, the car is making 526 rear wheel hp (392.8 kW) or in the vicinity of 650 flywheel horsepower (it ran out of fuel pump and the belief is that it will - with a new pump - be good for an additional 40 rwhp or 700 flywheel).
The kit is now going in to production and will be offered the world over.
Installation will take a good mechanic no more than one day to complete.
Now to your specific questions Dr. Bob.
Performance wise, the vehicle in question is now capable of covering the quarter mile in a little over 10 seconds at 141 mph, and is certainly quicker than an F40, F50 and virtually any other vehicle you would like to name (never mind the braking ability :).
Extra maintenance isn't really needed for the simple reason that with low boost the engine really is not being punished, particularly given that the extra power means the engine doesn't need to be revved. This said, if given too much power too often via hard launches, the clutch won't last and one wonders how the trans would go under these conditions.
Under normal road and hard mountain driving, no dramas at all.
Regarding broken engines, we've spoken with Ferrari insiders, and they believe there should not be any poor effects in either the short or long term.
Now if you would like more info on the kits, I can supply as desired.
Please either contact me through this forum or at:
[email protected]
cheers.
I don't have a Ferrari or any car myself so you won't make any money on me, but does the car only receive extra hp, or does it get a stiffer suspension, or bigger brakes? You won't need those if you only use it for the street, but for the track it would be nice. On the other hand, for the track you need a complete reinforcement of the drivetrain. Do you have any pics of the conversion? I saw you had some problems posting pics, just sent them to [email protected] and I'll post them for you.
And something more specific: Do you know the chassisnumber of the car that had the conversion? If you don't want to give it out to the whole world you can also PM it to me.
Is this the first Ferrari you guys did, or only the first 355? I know Norwood in the USA did some extreme 1000 hp Testarossa's.
Nice installation. A couple of questions, from a turbo owner (91 Toyota MR2 Turbo)
1) what turbos are you using?
2) have you plumbed the exhaust to use the stock muffler?
3) why have you decided to vent the Blow off Valves to the air instead of plumbing them to flow the air back in front of the turbo intake? By doing so you dump air that the ECU has already used to calculate the proper air/fuel mixture and increase turbo lag.
More on what I'm talking about:
http://www.jekylhyderacing.com/bov.htm
And see the attached photo for physical description of what I'm talking about.
Dr. Bob. Suspension and brakes - we do what a customer wants and is prepared to pay for.
Drive train reinforcement is not needed.
Chassis number....umm, don't think the owner would like to give it out.
Senna21.
Please refer to the following for full details. There are no blow off valves! and the wastegate is plumbed back into the fabricated exhaust system (you can't use a stock exhaust or muffler.
Two Packages are offered as follows:
1) 575flywheel hp (355kW) at wheels (6-psi boost)
· Pre-programmed MoTeC ECU M800 with plug in loom adaptors (can be upgraded to include traction control, Lambda, logging and so forth).
· MoTeC loom and associated fuses.
· High-flow 4-spray fuel injectors.
· 2 x High-flow Garret GT roller bearing turbochargers.
· 45mm Turbosmart wastegate.
· 2 x custom high volume tube and fin intercoolers with cast tanks.
· Thermatic fans on each intercooler with On temperature of 28c and 22c Off via MoTeC switching.
· Custom large volume Air Cleaner box with low restriction K&N filter element mounted under bonnet vent and associated tubing, cast in aluminium in either polished or powder coated finish depending on customer’s requirements.
· Turbocharger exhaust manifolds 3mm stainless steel or cast (depending on application (depending on catalytic converter).
· Same with cast stainless steel wastegate plumbing.
· 2 x Cast aluminium pipe from inlet manifold to intercooler pipes.
· 4 x 76mm rubber ‘hump’ hoses (intercooler/inlet).
· 6 x 76mm silicon rubber hoses (turbocharger to intercooler and turbo to air cleaner plumbing).
· 20 x stainless steel hose clamps.
· 2 x aluminium weld on dash-10 sump fittings for turbo drain back hoses (depending on quantity we will cast a higher volume CNC machined sump with integral drain back holes).
· 2 x braided stainless steel turbo drain back hoses.
· 2 x braided stainless steel turbo feed hoses.
· 4 x braided stainless steel water feed and return hoses.
· All copper washers, banjo bolts, T-pieces, gaskets and hose clamps to suit above.
· High-flow dual inlet and twin outlet 3-inch in and out stainless steel muffler.
· CNC laser cut turbo-mounting bracket.
Indicative current buying price: AU$42,000 + shipping and insurance.
2) 650hp and 400 rwkw (9.5 psi boost)
As above plus:
· High volume package.
· Modified programming.
· Modified wastegate.
· High volume fuel pump.
Indicative current buying price: AU$47,000 + shipping and insurance.
For those who would like to know a little more about the company behind the product, please refer to the web sire: www.nizpo.com.au.
Why have you decided not to use BOV's? Not questioning you, but wondering. I know that with standard journal bearing turbo's, the shaft can be split by the reverberation of air from the throttle body closing, compressore surge. Not immediately, but over time. With ball bearing this is less of an issue, I know, but that is still alot of air.
Turbosmart does make excellent BOV's, as I know you are aware.
Turbo's typically run between 800 deg F and up to 1800deg F. See the exhaust is red hot too, so you are looking for maybe around 1800deg F.??? Somewhere in that neighborhood.
Thank you very much for the welcome.
For all those interested, we are working with Nizpro to become the sole dealer for them within the US and the only dealer outside of Australia. We are very excited about this opportunity, but right now we are only in the preliminary stages of negotiating for the kit.
1 - 20 of 38 Posts
