Hi Guys,
I have been developing a starting prob on the 308gts. Sometimes when I go to start it there is nothing when I turn the key. The immobiliser activates, the fuel pump starts, but it doesn't wind over. I initially thought that it may have been a faulty immobiliser, but I suspect not, otherwise the fuel pump would have no power. I'm guessing it could be the starter motor?, however I'm no mechanic. It appears to have been getting worse, used to take a couple to turns (of key) to start. The last time I took it out, it took about 12 times the first time, about 6 the next (5 mins later) and about 4 the next time (15 minutes later). I could be wrong but it appears to be worse when cold? Anyone had this problem before? Any help appreciated.
Regards
Argento308
Regards
Argento308
