Common problem with modern, fuel-injected Ferraris. Its to indicate problems with the catalytic-converters. It sometimes is the case when the cats plug up, but this is seldom. Most of the time its the ECU's which have these cat sensors hooked up to. A quick diagnosis if its just one slow-down light that lights, locate the ECU's and switch connections. If the other slow-down lights, then it was that ECU.
If switching ECU's doesn't change, then it could be the sensor.
If you are handy with tools and have your appropriate Workshop manuals and Parts Catalogues, you can do this at home. Otherwise, go to your dealer.
