I finally changed it out. As you can see I was starting to have problems with the old one. Many people say this is the single best upgrade you can do on a 308. It took an afternoon and cost about $40. Universal fuse holders from NAPA, a strip of aluminum, some pop rivets, new screws, a soldering iron and some piggy-back spade terminal connectors. One of the easier jobs I've done on the car. Making a new fuse panel is actually easier than changing the oil. Cleaner too! You can see on the back where I soldered 12 gauge solid copper wire to replace the old buss ties.
If you don't have a soldering iron or pop rivet gun you can just buy these fuse panels already built from Birdman for $100 http://www.birdmanferrari.com/ Save you from running around town chasing all the parts. If you get Birdman's fuse panel all you need is a screwdriver, a magic marker and 15 minutes of your time.
