Hi, any advantage to using octane booster for an engine with only an 8.6 compression? Highest grade I can buy at local pumps is 91. Thanks :-?
If you mean the stuff you add at the pump you won't see a whole lot of boost, probably not anything noticeable at least.jungathart said:Hi, any advantage to using octane booster for an engine with only an 8.6 compression? Highest grade I can buy at local pumps is 91. Thanks :-?
As others here said, don't bother. On a lateral note, i DO suggest using Chevron Techron gas additive to clean injectors about every 10k miles depending on your driving habits/usage. This helps keep the injectors clean. Of course the occasional 'Italian Tune Up' is a good idea too.jungathart said:Hi, any advantage to using octane booster for an engine with only an 8.6 compression? Highest grade I can buy at local pumps is 91. Thanks :-?
Sounds cool. BTW not being Italian, would I have to pay someone somekind of commission to do the 'Tune Up' myself?? LOL :lol:enjoythemusic said:Italian Tune Up = after car engine/oil/water is warmed up, drive in a lower gear (to adhere to legal speed limits) yet have RPM at about 6.5k rpm for about 30 seconds.
