My 355 all of a sudden will only blow outside air with no heat or cooling when set. Not sure what is wrong but would like to see if anyone else had this. Possible vacuum leak or damper issues?
Thank you
sebastian
Sounds like the clutch on the A/C compressor is not electrically engaging.
I would check your fuses.
