Dr. Bob said:
Look at these attached pics. There are a lot of teams struggling with new wings due to new regulations, the front wing has to be higher, so less downforce can be generated. What suprises me most is that the front wing of Ferrari is not even symmetrical. Is this due to left or right turning circuits, or because some parts of the car need extra cooling?
It looks symmetrical to me. What part of it do you see on one side that doesn't match the other? Maybe I'm missing something but I'm usually very good at catching this kind of thing.
If you're referring to the bit hanging down in front (we'll call this the "appendage") of the normal looking wing; that appears to be where the
loop-hole in the rules is.
The closer you get that wing to the ground the more downforce it'll develop. Which is why the FIA decided to raise the front wings to reduce downforce. This is because the air gets squeezed between the ground and the wing and increases the acceleration of the air under it. When the air under the wing is faster than the air over it a high pressure (downforce) area is created on top and a low on the bottom. The "appendage" although small (and ugly) is still creating downforce and more than if it were higher up.
It's all more complicated than that naturally, but in the interest of time the answer is:
Ferrari saw a loop-hole in the rules to add another wing lower than what the rules stated and did so. Remeber the X-Wings that appeared in the late 90s and then again on the front of the Orange Arrows in the 2001 Monaco GP? Same thing.
Now, whether or not Bernie will tell Ferrari to get rid of it's Appendage as he did then remains to be seen. If he doesn't I'll bet you'll probably see more teams showing up to testing with the same style front.
