Here is that info:
The engine's aluminum block had Nikasil-coated wet steel liners. Peculiarly light forged aluminum alloy pistons drove the crankshaft through titanium alloy con rods previously seen only in Formula 1 engines. The engine's greatest innovation is its five-valves per cylinder, three intake and two exhaust, that combined high revs with high intake permeability maximizing gross efficiency. The aluminum head was ultra-high strength with variable rigidity dual valve springs. The radial intake valves made conical cam profiles necessary and the high rotation speed necessitated a high lift for both reliability and long-term performance. The control lobe for the central intake valve was slightly offset, reducing pulse stress and the emission of un-burned hydrocarbons. The valves were actuated by hydraulic tappets with automatic play take-up, a first for engines that rev over 8000rpm. In accordance with racing design, Ferrari engineers created an extremely compact high-swirl combustion chamber of 11:1 compression ratio. The engine was controlled by a Bosch Motronic M2.7 twin hot wire electronic injection-static ignition system, and lubricated by a dry sump engine oil circuit.
