I have a 330 GTC that has an oil cooler built into the radiator. When I first start it after sitting overnight, it takes 20 seconds after the engine starts while the engine is idling, before the oil pressure needle moves from 0. If I let the engine warm up and let it set for 15 minutes and then re-start it, it only takes 2-3 seconds for the oil pressure to build up.
I have tried both the Fram 28041 and Baldwin B253 oil filters.
What should I check?
Thanks,
Enzo
Thanks,
Enzo
