941 - 960 of 986 Posts
Discussion Starter #941
At daylight, the Smart LED DRL - Ultimate EV1 lights of the F430 are very bright and avoids the car been overlooked. A vast safety improvement in addition to a more updated look. It's smart, so it will dim these lights when the turn signal/direction indicator lights or the low beams are turned on. All brightness levels are easily user configurable right from the driver's seat.
With the Smart DRL Lighting Controller ECU, you can make these DRL lights turn on at distance with a remote and automatically when the engine is started. They will stay on for 1 minute then automatically turn off when the engine is stopped.
All Plug & Play and easy to install as it was made originally.
https://www.scuding.com/Shop/en/ilu...430-headlight-smart-led-drl-ultimate-ev1.html
Discussion Starter #944
Discussion Starter #945
Discussion Starter #946
Discussion Starter #947
One of our most liked solutions: The Ferrari F430 Smart DRL Lights - Ultimate EV1 together with the optional DRL Lighting Controller ECU.
It's smart because the brightness levels will vary depending on the turn signal lights or the low beam lights. And with the DRL Lighting Controller ECU, you can turn the lights on at distance with the remote control unit as well as have them turning on automatically when the engine is started. After turning off the engine, they will remain on during 1 minute, just as modern cars do today but even better.
Photo from Greece shared by a happy customer.
Discussion Starter #948
Vendor
Discussion Starter #950
Discussion Starter #953
Would you like to hear rather discrete click sounds from our electronic Smart Turn Signal/Direction Indicator Lights ECU? This ECU can be easily configured to simulate old fashion relay click sounds since firmware V2.8. Check our video below how to do so.
For Ferrari F430 - Scuderia - 16M, 360, 575M, F355, 550, 456GT/M, F50 and F512M
Maserati Coupe/Spider/GS
Lamborghini Murcielago
BMW 3' E36 + M3, 5' E34 + M5, 7' E32, 8' E31 and Z3 E36 + M
Read more on https://www.scuding.com/Shop/en/ecu-solutions/102-smart-tls-ecu.html
Discussion Starter #954
I liked how this USA Ferrari 360 owner installed the Smart Turn Signal Light ECU, which is part of the complete LED rear lights package, and wanted to share this so it can help other 360 owners. Using heavy duty reclosable fastener on the side of the ECU (3M, Scotch, etc).
For a complete installation guide, please follow this link: https://www.scuding.com/Shop/en/ecu-solutions/102-smart-tls-ecu.html#installation
Very nice!
I did the same thing on my F430 Spider, I used 3M heavy duty velcro to attach the smart Turn Signal Module to my car.
Works great, it stays put.
Thanks for the great products you make for our pride and joy cars Stef!
Keep up the great work.
Dan
Discussion Starter #956 (Edited)
Discussion Starter #957
Our SMART TURN SIGNAL-DIRECTION INDICATOR LIGHTS FLASHER ECU can be very easily installed, it's just Plug & Play and take immediately advantage of the numerous new features in addition to a greater reliability compared to the old OEM flasher relay.
Read more here: https://www.scuding.com/Shop/en/ecu-solutions/102-smart-tls-ecu.html
For Ferrari F430 - Scuderia - 16M - Challenge, 360, 575M, F355, 550, 456GT/M, F50 and F512M
Discussion Starter #959
This is how the Ferrari F430 rear lights should look like with all 4 taillights turned on for increased safety and greater modern look.
Our LED rear light packages are totally Plug & Play and integrate the Ferrari as it was made originally. No extra buttons or wires to splice.
Available for Euro and USA spec F430-Scuderia-16M-Challenge, Enzo, 360, 575M, F355, 550, 456GT/M, F50 and F512M
https://www.scuding.com/Shop/en/6-ilual-led-reartail-light-solutions
Very nice!
