901 - 920 of 992 Posts
Discussion Starter · #902 ·
Some photos kindly shared by a F430 UK owner and well known reputable race car engines expert. He made all possible upgrades on his F430 with all our products and is very satisfied with the overall improvements.
Here's some of his feedback starting with the front upgrades made on his F430:
"Smart Turn Signal Light Flasher ECU: It was this product that first drew me to your website, my original flasher unit had very little audible out put. I found installing your “Smart TSL ECU” very easy (via your online instructions) and made no alterations to the configuration as I found your factory settings ideal. I find it a nice modern enhancement to the car."
"Front LED Turn Signal Lights: An easy to fit update which adds more reliability to the lighting system of the car, as your advert mentions, you cannot see too much difference in the brightness from the OEM, but the increased switching speed is very noticeable. Coupled with the rear lights upgrade its a worth while purchase."
"Smart LED DRL Headlights: This is a very good upgrade, the difference in brightness and general aesthetics of these LED DRL is considerable. it certainly makes the car stand out, (not that it doesn’t do anyway!) again I found the online instructions clear and concise and were no problem to fit."
More to come...
Discussion Starter · #904 ·
and now the rear upgrades:
"3rd Brake Light with Flasher Module: I spent a little bit of time with the plug and play facility on this light but ended up going back to the factory settings again as it looked the better setup. Easy to install, fitted well into aperture, as before good instructions from your online download. I did install a length of heat resistant “Heat Shrink” over the earth cable as this is exposed above the exhaust silencer when the engine cover is closed."
"Rear Light Clusters “Clear Centre”: I purchased 4 off these light Clusters because two of my originals were damaged. They were no problem to fit and in my opinion they are as good as if not better quality than the originals, and certainly better constructed around the mounting points. The addition of the rubber insert washers is a welcome improvement to the overall strength of the light assembly when attached to its mounting brackets, the light unit even though it still flex’s a little bit feels nicer than the original fitment. The clear centre lenses of the lights certainly smooth out the aesthetics of the back of the car. "
"ILUAL43 EUR Tail Light Kit: Very nice and well engineered upgrade, again the online instructions were clear and easy to follow, because I was fitting them into your light units I did not have to make any modifications to install the lamp holders. All the cabling and electrical connectors are off high quality and connect well and positively with the original sockets. When installed on the car they look terrific, all the new lamps front and rear enhance the car considerably."
Discussion Starter · #907 ·
Discussion Starter · #908 · (Edited)
https://www.scuding.com/Shop/en/ecu-solutions/102-smart-tls-ecu.html
Our Smart Turn Signal Lights ECU is a Plug & Play replacement of the OEM flasher relay. Not only it's a 100% electronic solid state solution which will last forever, it offers also several new smart features like the alarm fast flashes when the doors are locked/unlocked or the alarm goes off. This makes it well more noticeable than the original steady on lights.
You'll enjoy also the "Soft touch" automatic flashes which will flash automatically the direction indicators a number of times when you press the level shortly. And the click tones are well more audible too. All settings can be easily customized without needing to remove or access the ECU.
A great and easy way to make your F430 more modern.
Plug & Play also for:
Ferrari 430 Scuderia - 16M, 360 - CS, 575M, F355, 550, 456GT/M, F50 and F512M
Maserati 4200 Coupe/Spider/GS
BMW 3' E36 + M3, 5' E34 + M5, 7' E32, 8' E31 and Z3 E36 + M
Discussion Starter · #909 ·
Some feedback of a happy Australian F430 owner who installed the following solutions on his car:
"The DRL lights and Smart TSL systems are working well and is a definite improvement to the OEM. Thanks to your Smart eMT ECU, it alerted me that I had a fault with my F1 system. The Ferrari dealer confirmed the fault was with the accumulator and have since replaced it. So far so good and the car drives beautifully... smooth gear changes. I also love the front LED’s and one touch indicators."
FERRARI F430 SMART LED DRL HEADLIGHTS - ULTIMATE EV1
SMART EMT F1 RELAY ECU
SMART TURN SIGNAL LIGHT FLASHER ECU
could he not re-design the bulbs w/ a better , more efficient heat sink ? so they would produce less heat ? can the tailight housings be vented to shed heat better ? yes heat is an issue in the desert without question !
Discussion Starter · #912 ·
that link to e bay said " page not found " Have you another link ? thank you !
I guess you're referring to the first pages of this thread which are now quite old and technology has changed a lot since. We ended up designing our own LED lamps using only CREE LED chips and are directly integrated on our rear light PCB - circuit board (no lamp contacts). They don't heat and there is no need to add any additional venting in the housing which must remain waterproof.
Hope this helps ;)
Discussion Starter · #913 · (Edited)
This German Ferrari F430 has been completely upgraded with all our products available for the F430.
- Complete EURO LED rear lights package including the center stop light safety flasher + 4 new rear light clusters
- Smart LED DRL Heaqdlights - Ultimate EV1 Version + Smart DRL Lighting Controller ECU Module to turn on/off automatically the DRL lights when the engine is started/stopped
- White engine bay lighting system
- Red interior lighting system
- Smart Turn Signal Light ECU
- Smart eMT F1 Relay ECU - Advanced Version
Many thanks to the owner for sharing these photos of his stunning F430.
Discussion Starter · #914 ·
https://www.scuding.com/Shop/en/ilu...olutions/99-ilual36-led-rear-lights-euro.html
This complete LED rear lights package for a Euro Ferrari 360 is ready to be shipped. A complete long duration bench test is always made for each product before shipping.
Every component is carefully wrapped in anti-static bags (ESD).
We ship daily worldwide by FedEx Express and packages are usually received in 1 to 4 days depending on the destination.
Very nice!
I have this complete kit on my 2003 360 Spider and I absolutely love it.
Great design, excellent build quality, much brighter than stock bulbs, consumes much much less power, bulbs doesnt get hot, and being LED's this should last a long long time.
Excellent support too from the seller.
Dan
Discussion Starter · #916 ·
Many thanks Dan :thumbsup:!
Very nice!
Dan
Discussion Starter · #917 ·
Another nice upgrade ready to be shipped for a Ferrari F430 in Finland:
EURO LED rear lights package:
https://www.scuding.com/Shop/en/ilu...olutions/97-ilual43-led-rear-lights-euro.html
Front Smart LED DRL Lights - Ultimate EV1:
https://www.scuding.com/Shop/en/ilu...430-headlight-smart-led-drl-ultimate-ev1.html
Smart eMT F1 Pump Relay ECU - Advanced version:
https://www.scuding.com/Shop/en/ecu-solutions/101-smart-emt-relay-ecu.html
With our solutions, it's easy to make your car more modern, more reliable and well safer!
Discussion Starter · #918 · (Edited)
Discussion Starter · #919 ·
A nice and aesthetic way to improve safety is to make the Ferrari F430 more visible with our super bright LED DRL Lights which are powered by our micro-processor based Smart modules. They are Smart because they will automatically dim the LED DRL Lights when the low beams or turn signal/direction indicators are turned on.
NEW: since firmware V2.1, the brightness levels can be now configured without needing to physically access the Smart Power Supply modules but by making simply usage of the high beams lever switch! Comfortably installed in your car, you can now set your own brightness levels when the parking, low beam or turn signal lights are turned on.
Discussion Starter · #920 ·
A complete upgrade of a Swiss Ferrari 430 Scuderia, ready to be delivered to the customer. Winter time is the best moment to give you car a little love ;)
- Smart Turn Signal-Direction Indicator Lights Flasher ECU + 2 front LED Turn Signal lamps (F430)
- Complete ILUAL43 EURO LED Rear Lights Package + ILUAL3BL Full Line LED 3rd Brake Light
- F430 Smart LED DRL Headlights - Ultimate EV1
- F430 Smart DRL Lighting Controller ECU Module
https://www.scuding.com/Shop/en/ilu...ions/70-ilual43-headlight-drl-ecu-module.html
- Smart Engine Bay LED Lighting System V3 - White
https://www.scuding.com/Shop/en/int...113-smart-led-engine-bay-lighting-system.html
- Clear Side Turn Signal Lights F355-360-F430-599-458 (pair)
https://www.scuding.com/Shop/en/light-clusters/20-clear-pair-of-turn-signal-lights-f360f430.html
