1 - 2 of 2 Posts
Hello,
I've got a bit of a problem with my Ferrari 456 gt. The airconditioning unit under the dashboard seems to be leaking water. When I drive the car for a about half an hour the carpets in the passenger footwells are really wet. I've removed the carpets and after driving again I noticed that the heaterunit under the dash is all condensated. What could be the cause of this problem?
With kind regards,
Tazio
blocked condensate drain line is the first place to look. Not sure exactly where it is on a 456. Do you notice a puddle of water under the car when AC is on? You should...Where ever that puddle usually is you will find a hose coming from the bottom of the evaporator coil drip pan. Run a small piece of semi flexible wire up that hose.
1 - 2 of 2 Posts
