Hi Guys,
Bit of help please if you can.
When I recently put the right hand indicator on, the bulbs inside and out flashed very very quickly. Obvious answer was a blown bulb!! The front right bulb appeared not to work but I tested it on the left side and it worked fine. I played around with headlights and after a while the indicator worked properly (probably a coincidence). Things worked normally for a few weeks of motoring but the problem has returned. I replaced the fuse of the hazard lights as this was in fact blown but right hand indicator still flashing rapidly. Has anyone experienced the same or have a clue as to what the problem could be? Now, because I have been starring at these indicators, the left side seems to flash a bit quicker than I remember. It may be my imagination but they are alittle quicker than the hazards when they flash.
Gratful for some help please.
Regards
Stuart
Regards
Stuart
