Do any of you service your own cars and have any good tips on how to lift the car in a residential garage?
I want to change the engine and gear oil in the 456, and I have jack stands and a hydraulic jack, but I am worried about damaging something in the process of lifting the car. The car is so low. Although it might be cool to install a real lift someday, I was hoping to avoid that in the near term.
Let me know if you have any thoughts.
Thanks,
Ed
Ed,
I would recommend a low clearance ramp that the two front wheels drive up. I have used ramps before and trust them a bit more than I do jacks and would not recommend a jack, too dangerous.
Here is a link to low clearance ramp:
http://www.discountramps.com/low_profile_car_ramp.htm
You might want to search around on Google for others as well but these should work well for you and they will get the car up enough.
Ditto
Ed,
The mechanic I trust my cars with uses similar ramps made out of wood. What he does is set a pair of ramps for the front wheels to drive up to first: then, he uses hydraulic jacks (two) to lift the rear and then sets the car on jack stands. Works fine and it takes only few minutes for it. Jimmy
