Hi Guys new to this group, Ive had my 328 for around 30 Years now, I have what i think is an oil leak, not when running but when switched off and cooling down, its coming from
where indicated on the attached picture, please can someone give guidance on this before I phone the dealership and end up paying the F price's. Thank you for your time.
Automotive tire Motor vehicle Tread Fender Art
That is just a vent for the trans. Is it overfilled? The drain and fill check are on the back. But there is a fill for the engine transfer gears that might have been overfilled. Has anyone been been servicing it lately?
I had similar problem with my old 328. The excess oil is from the engine, the shifter shaft passes through the crankcase and into the trans. Over time the oil from the engine leaks into the
transmission until it is overfilled, and will dump out after a good drive. You can replace the shifter shaft seals, or drain the trans and refill to correct amount. Monitor the trans so it doesn’t fill up again. It will probably take a while for it to overfill again. That way you can keep driving tha car.
Yes, that shift shaft has 2 seals. Engine and trans are seperated by an internal seal. Buy some seals and gaskets. Drop both pans. Disconnect shifter and front motor mounts. Jack engine up. Remove shift lever inside trans and slide the shaft out. Have at 'er.
