While reversing my car one day up a slight slope, I stuck the gear into reverse and depressed the clutch. Instead of reversing, the car rolled an inch forward and came to a halt. At this point the engine is still idling, gear in reverse and my foot off the clutch. When I tried to take the gear out of reverse it did not want to come out and felt as it was stuck. So I turned off the engine and forced the gear out of reverse and into neutral. However the car was still stuck and would not roll down the slope freely which it should being in neutral. A bit annoyed I left the car and came back after afew hours and found it to work fine.
This is the second time this problem has occured and after talking to afew independent garages no one seems to know what the problem is or have ever come across it. Does the clutch need replacing as the biting point is quite high or is it the gearbox.
Any help will be appreciated.
