1 - 15 of 15 Posts
i have read that the mondial has problems with its fuse box, can any shed light on what the problems are.
gary
3.2 Series
We should first address your model, the 3.2 with corresponding electrical system. Perhaps branching in the title to include 3.0 or 3.4 can be done later.
Anyone want to go first, as I am not as versed on older models.
rik
Mondial Fuse Block
The problem with Mondial Fuse blocks are the fuel pump, starter circuit, and slow windows.
The different layers of the circuit board separate when the car begins to get warm. The most frustrating problem is the non start of the fuel pump and starter motor.
Every one that has had a problem with the fuel pump and starter has had to bypass the fuse block by removing the relay and running a separate hot wire from the battery and cutting the fuel pump and starter wire at the fuse block.
The slow windows will need to also have a hot wire run to inside the door and a set of relays installed to boost the voltage to the window motor.
I hope this answers your questions.
Charles
I have been finding info on replacement Mondial fuseboxes.
So far this is what I found:
Fusebox US$1200 - lead time 6 weeks
Wiper control unit about US$150 - lead time 4 weeks
I will get more info on ordering and availability. I believe these are being made in Singapore.
Sure sounds like a ton of $ to me but to have an updated and contemporary fusebox to prevent constant electrical problems I would think is quite valuable.
I believe in posting info I believe is valuable for everyone
I keep files on issues for cars I do not yet own, because for sure I will be buying a few other cars. It's invaluable to have that info available.
The fusebox issue is somthing critical and I am certain to buy a 308GT4 and maybe even a Mondial.
So this benefits everyone.
You can get them rebuilt with a new tech circuit card on an exchange basis through GT Auto Parts in Az for a lot less. I have their prototype #2 and it works wonders.
The $1200 was for a new build which I do not know if they are actually available.
Good luck!!
I don't see much price difference from GT Car Parts except for the fact that they are domestic.
They do 328's, Testarossa's, and Mondials.
It's done on an exchange basis.
Good info though, Russ.
To be a bit blunt, in my experience the price difference was almost $400, which is even really a bit moot, as I have not really seen that the new build units are even available in reality. Even then, the support of that product is tenuous. Clive is a great guy, but he has another job to focus on.
It's like asking me to make an exhaust - I do a great job within limitations, but its not my focus and I might be less able than a pro like you. :)
All well said and I am quite concerned as to his designated sales agent for the US!
A friend is $2,600.00 into him for work never done on his 328 and the new "distributor" is no longer in business.
So your source in Tucson does make more sense!
BTW, I think you did a great job on your exhaust. Want a job?
Was this the same man with the pullies? I thought he was still up and going.
Just got an interesting PM solicitation from a new FL guy offering new, re-mfgr'd fuse blocks for all the Mondials to include the T.
there were several types for the T to include the cabriolet and coupe and PRE-1990 versions, as 1990 had a couple less 'extras' on the car.
I will keep you updated. BTW, IF you find a T's block expect to pay between [Lucky] $990-1,400 USD. I got one delivered from Europe five years ago for $900 US and considered myself VERY lucky.
will be interesting to see what this response will be like.
rik
1 - 15 of 15 Posts
