I can understand older, carb'd 308's with strong fumes, but not usually 328's. Their fuel injection systems are completely sealed with very good fuel-vapour recovery on the gas tanks.
This only happened AFTER you lowered the windows? Could you distinguish the type of fumes you smelled (pin-point it to either gasoline, hot/burning oil, antifreeze)? I'm not saying this as a joke, but did you hit some small form of wildlife? The ventilation system draws air in on the Driver's side of the opening of the air-dam and this is very close to the road, easy to scoop up tiny animals (again, I'm not saying that as a joke...).
Have you had the car in for servicing lately? If so, what type of work did they perform? They may have left something off, or forgot to tighten up something...
