1 - 11 of 11 Posts
One of the dealers in my area refuses to sell Mondial's based on his allegations that the car has too many electrical problems. Although he feels it would be a profitable way to make extra money, he doesn't need the aggravation from customers. He sells all other Ferarri's.
I thought that all Ferrari's in the 80's were temperamental when it came to electrical issues. Does any one have specific experience with say Mondial and 308 /328' s ??
Yeah, the electrical system is weak. Power windows are a common problem as well as fuse panels.
Is there any upgrade available to the fuse panel? Can it be fixed?
(I saw a reply once that mentioned bypassing the fuse panel would help the window problem. An new intermediate fuse would have to be added).
I know a bunch of 308 owners have replaced the fuse panel with a universal panel from NAPA that uses the glass AGC fuses rather than the stock plastic GBC fuse with the exposed fusible conductor.
You should be able to do it yourself for under $100. Here's a couple of pics of bad fuse panels and some owner-installed replacements. The glass fuse one I mentioned earlier and one using the ATC blade-type fuse.
Discussion Starter · #7 ·
Sounds like a neat project along my line of experience: I am an electrical engineer!!!
I may buy the car after all.
Thanks!
Shoot, you should be able to fix any electrical problem with the car. It ain't high-tech stuff on the early '80's cars. The main electrical problems are when you get a bunch of Italians trying to wire up 500 cars after their pasta and vino lunch break and you are lucky if the headlights come on at all without starting a fire. An electrical engineer ought to be able to get one car right.
Pete04222 said:
...The main electrical problems are when you get a bunch of Italians trying to wire up 500 cars after their pasta and vino lunch break and you are lucky if the headlights come on at all without starting a fire...
Eh, what Peter's saying here is that these are truly hand-built cars! 8)
"Mondials Rule!"
Discussion Starter · #10 ·
I agree. The only issue that I was worried about was the quality of the cable, as well as the kinks that may be inaccessible without removing panels, etc.
In addition, a weak fuse box causing a faulty connection, can increase the wear and tear on the relays and other related equipment such as switches due to constant current and voltage spikes.
But it's woth a try. Thanks again.
use stabilent 22 on all connections . rear qtr windows can sometimes be repaired . tricky getting them out of the pocket though . forza frank
1 - 11 of 11 Posts
