Anyone know if you can fit the Ferrari FF or F458 Carbon Ceramic brakes and rotors on a F430?
Wrong size, I believe, and wrong bolt pattern for the hubs (5x108 mm vs 5x114.3 mm). Only 380 mm on an F430 and 398 mm on the later cars.
Have not looked at changing the hats from the F430 to the later rotos, but you would still need caliper adapters if that worked.
Mov'It makes far superior replacement ceramic rotors and pads, but they are expensive.
360Trev has 398mm brakes from a 430 Challenge car on his 360 (albeit on 19'' centerlocks).
I'm unsure if you can swap out the center bells with your current ones for the right pattern; although it should be. Trev swapped the center bell for much lighter 430C center bells for his centerlock wheels (and they look brilliant).
He notes he doesn't have much between the calipers and the wheel now, though!
A very detailed post here:
360Stradale 6 speed manual conversion - Page 11 - FerrariChat.com
(unsure if I'm allowed to post an Fchat link here, a mod can remove it if necessary).
