1 - 20 of 32 Posts
Vendor
Hello at all,
for both Ferrari 550 and 575 I developed one center section that maximizes the engine performance (in comparison to the OE muffler and/or x-pipes) as the straight pipes, and in the same time it delete the drone inside the cabin caused by the straight pipes or by some type of back boxes mufflers.
I did more tests on my 575 before to arrive at the final solution, that for me is the best, some of you have followed me last year when i explained my tests ....
I called my center section "double H-pipes", in detail there are two straight pipes connected by two little cross pipes that do sound balancing and not gas flow balancing, in this way there are not the losses of x-pipes (also if little) but the two cross pipes delete drone, I did some tests for find correct diameter and position of cross pipes.
I make this center section in three parts, in order to make easy both shipping and installation, first part is common for 550 and 575, the difference are the two pipes that are at the sides of gearbox.
The kit is composed as following:
- N°1 double H-pipes with heat shield (item 1 on image)
- N°2 pipes (item 2 on image)
- N°2 stainless steel clamps (item 3 on image)
Kit is installable in the original exhaust system, is perfectly fitting, at the both sides, to the OE CAT and to the OE back pipes.
Weights (including clamps):
F550 Kg 7.4
F575 Kg 8
Vendor
Discussion Starter · #2 ·
Following some pictures of molds necessary for make center sections, in order the new bending tool and a mold for make the pipe suspension hook for the F550 center section.
Vendor
Hello guys,
today my company supplier have completed the bending of my pipes .. a lot of pipes ....
Next week will be delivery to my shop, as per picture, the result appear very nice ....
Following the video of the bending process by means of CNC bending machine .... this machine it cost over 350K eur ... !
After that construction will be restarted !!
Early will be some news ....
Best regards at all.
Great work Fabio, Looks much nicer than the Bradan Center resonator delete I have now. When will you have prices set?
Super Moderator
Gorgeous Fabio! They're the best looking center pipes I've ever seen.
Like Dave, I'm also interested in price & availability.
Fabio- Very, very nice.
Vendor
Discussion Starter · #7 ·
Hello guys,
it was passed one month from my last posts, due to the christmas holidays, was delivered to me only the 9th of jan ....
I saw only this morning because i was at home with fever during last 5 days!
However now are in my shop, the company worked in wonderfull way, excluding two/3 pieces used for setting machine, the other are bended without any imperfections or section restrictions...
I'm surprised of the result, much better than the bends on the original pipes, or of some other exhaust system that is on the market ....
For the other side, this company working for the automotive brands, have modern machines and more experience, that is more important ....
Follow pictures of some pipes that i have ordered (between pipes are visible also the check calibers for the pipes, that i have cad designed and manufactured by myself by means of laser cut pieces; expensive but they make guarantee of the tollerances)
Best 2107 at all!
Vendor
Discussion Starter · #9 ·
Hello guys,
yesterday I made the first "double H centre section" for F550, now that I have the pipes expander machine (made by myself) i could make the connection without an intermediate element .
Now need welds and, last thing, the heat shield on the double H part.
As you can see, I made the support like the OE for obviously reasons ....
Vendor
Discussion Starter · #11 ·
Hello,
this morning i picked up from my welder the double H-pipes with extension pipes and a x-pipes for a my friend because he want to test both types....
Now remain only the heat shield and the edge pipes cuts for clamps on the double-H.
Best at all
Fabio
Fabio- Great craftsmanship, as expected. Your friend needs to compare the X-Pipe and the balance tube pipe on a dyno. He will be surprised at the results.
If I recall correctly, the H-pipe has better results versus the X?
Fabio, do you have anyone that has the full system for the 550 installed and dyno tested yet?
I've sent you a PM but haven't received a response. I'm willing to do a before and after dyno test with your full system on my 550.
Vendor
Discussion Starter · #14 ·
Ciao Nin,
i answered you the day that you sent me PM from my other nik where you sent me PM.
In fact i'm waiting your answer but nothing ....
I will send you again my answer, also from here.
sorry but perhaps server was in fault?...
Fabio
Vendor
Discussion Starter · #15 ·
Nin,
I had check now , i have only your request and i not have my answer ...
Sorry i'm sure that I wrote answer, also becasue your request is more important for me...
i dont know why .. for sure i did chaos during sending ...
Sorry again ...
I will answer you from this nik, only the time to write in english.
Best Fabio
Vendor
Discussion Starter · #16 ·
Ciao nin,
PM sent now....
Yes nin about both X-pipes and double H-pipes, in combination with my 6-1 headers, I had better result of sound and performance with double H-pipes, as pe rmy experience, X-pipes make a good sound on the 550 /575 with the original headers but decrease a little bit the performance, in way perhaps difficult perceptible.
Best Regards
Fabio
Ciao nin,
PM sent now....
Best Regards
Fabio
I believe Bradan from the other forum performed this test on the Maranello's as well and found the same result with the H-pipe being more desirable from a performance standpoint, which to me is most important. :)
Thank you for the reply! :)
Vendor
Discussion Starter · #18 ·
Hello guys,
the extension pipes for the F575 double H-pipes are under manufacturing ....
In the second picture are shown bended pipes for make the back straight pipes in alternative to the back mufflers.
Vendor
Discussion Starter · #20 ·
Hello guys,
yesterday I did a center section "double H-pipe type" for the 575 of a Flife chat friend who live in Germany.
Follow the pictures of the same centre section that I sent two weeks ago to a friend of this chat who live in Vancouver, and the pictures of the section for the 575.
I have in a shop materials for do 5+5 sets.
Regards
Fabio
1 - 20 of 32 Posts
