Frank,fmaderi said:hi, the engine slowing down may be only related to the 430 model .i am aware of 360 owners that complain of loss of power . i was reading a post from a guy in ltaly that was writing a book about it? . he seemed to know why the loss but thats as far as i remember. could it be a door/boot/deck cover switch going out ? what is the fluid level,condition, what is the anbient temp ? i wonder if some of these things slowdown the electro part of this electo-mechaniacl systems . like aselonoid wants to activate but is being held back . one of these days i hope someone can scope these buggers and see if i have anything here . i dont know if reseting the pis might help.i wish i had a car in the shop to try and solve/research this . i get alot of questions from people al over about this F1 . anyone out there have anything to share please pm me . thanks forza frank
The Shell Donax TX is fairly new. It is for trucks and heavy-duty fleet vehicles. If the car is still under warranty then you want to stick with that.Hello all,
My 360 has been shifting into neutral as well... However, the issue may be slightly different. My issue is accompanied by the F1 warning light flashing when the problem occurs. I think I have narrowed it down to a problem in the fluid level & pressure for the F1 system... The manual states I should use Shell DONAX TX fluid???? never heard of it!!! Is there an equivalent? I do not want to pour in the wrong stuff...
Thanks,
BigLen
http://www.shell-lubricants.com/products/pdf/DonaxTX.pdf
If you are looking for a replacement synthetic then the Redline D4 ATF would be acceptable.
http://www.redlineoil.com/products_gearlubricants.asp?productID=51&subCategoryID=18&categoryID=8
If you are just looking for something you can get at the local auto parts place to top it off today then any Dexron III will work just fine.
