My 355 Mo2.7 run well in high revs but under 3500 rpm sometime it run on -4 or 6 cylinders like if there was no ignition..Do you know what to look? It seam like if a sensor doesnt work...
nico
Discussion Starter · #2 ·
answer
I finaly found the answer !
One of the 2 ECU was bad plugged and was about to be unpluged with the vibating of the engine.
just plugged is well and the car is like new !
good to hear it was that simple :) A lot of thing I hear about bad ignition is about bad wiring. Is this only a Ferrari problem or does every manufacturer feature this?
