1 - 2 of 2 Posts
Guys,
I ave got a battery light that is constantly on on the dash. I have checked the charging and also the battery itself and all is fine. The light only seems to come on dimly.
Any suggestions to sort it out, other than £80.00 an hour labour at my friendly Ferrari specialist? Is this a comon fault?
Regards
Chris
Check the ground from your alternator to the oil sump. If you don;t have one, order it from your local dealer. If it is in place, try removing the connections at each end and cleaning them up. Also clean your battery connections, and the connector block on the right side of the engine compartment under the side plate. Remove all the connectors and clean them up.
1 - 2 of 2 Posts
