Hi,
I have the following problem with a 1996 F355 Berlinetta. The ABS Light is permanently on. Can't read any fault codes by inserting the fuse in the diagnostics socket next to ABS ECU as the ABS warning light just stays illuminated.
Would this indicated its not a sensor problem but some kind of other electrical problem? Or does the ECU somehow needs resetting first?
Any ideas??
Thanks,
Peter…
What would be the best way to reset the ABS ECU? Do I need to use the battery isolation switch or would it be possible without doing that and not loosing the radio settings?
Peter..
