1 - 6 of 6 Posts
My friend have a 430 Scuderia and are having problem with the F1 shifting.
The car wont start in 1:st but after some "thinking" it goes into 2:nd and drives fine. After starting in 2:nd he can go back to 1:st. Have anyone ever heard of similar problem?
Not sure I will ask...
There were apparently no error codes...
We share the same mechanic and I trust him fully, really experienced.
But in this case he/we are stranded, no clue.
They checked pressure, the relays and I think they are looking into faulty hydraulic actuator.
Yes, faulty hydraulic actuator may be causing this at cold. I would try too first to do a relearn but at cold in the same conditions and check the TCU error codes. A gear not engaging properly should normally trigger error codes.
1 - 6 of 6 Posts
