1 - 16 of 16 Posts
Hello everyone... New ferrari owner & new member to the forum...
I have owned my ferrari 360 for 5 months now. Recently, the F1 tranmission has begun "missing shifts" and going into neutral while upshifting, either pulling the paddle or on its own in AUTO mode... has anyone experienced this? Please help...
Thank you very much.
PS - I love my Ferrari... It has been a "life-changer" LOL! :drive:
Discussion Starter #7
FYI - For all who helped out..
The problem resided in a simple lack of pressure in the F1 system fluid. My car has a small leak and it needed to be topped off... A few dry-run shifts & a drive down the block and all is normal!!! :eek:)
Enjoying my 360 again... Total Cost to fix: $75 bucks for two liters of the factory recommended Shell Donax Tx fluid...
Biglen
I'm having just the same problem, the Ferrari dealer recommend a cluth change to solve the problem. A $8000 cost! I'll try your solution first ;-) Hopefully it's the same problem. I've been driving my 360 spider now for almost 2 years now and loving every mile of it. Going to Italy this summer along the lake's in the north. So this problem is one I can miss ;-) Will keep you posted if it's the same problem.
Clutch and clutch position sensor are the most common causes of that symptom.
If you have a quality independent get a second opinion like Wetpet says and price compare also. You should be able to get more for your money.
Well I checked the oil level as described in the manual and it was to low. So I topped it of with about 250ml donax Tx. Also did the dry run and then toon it out for à drive. All was well for about 10 Miles then it started again. The problem gets alot wors when I drive it then stop and a houre later I drive again. When I looked at the car the Next Day it had a big oil leak underneath it. Looks like all the oil I poured in came right out again. Try to find the source off the leak and looks line it came out of the filler cap itself. Getting desperated now :-( Going to an independent mechanic On wednesday, hope he can find the problem...
Hey Everyone,
Well we hooked up the ferrari computer and we have discoverd the problem. In the gearbox the gears have to much tolerance between eachother. It's like in a manuel, when you try to sift but the gear isn't there and you have to pusch it in. When the computer does'nt find the gear it goes in to neutral. That is the problem, now to solve it is an whole other problem :-S The guy I went to has'nt seen this problem on a 360. He wanted to do some research first. I called hem about 14 days ago and he has a 360 in the garage with just the same problem and he was going to do his first and call me when it was done. Have not heard him yet...
I'm just pissed at the official Ferrari dealer because he said it was a clutch problem and there is absolutly nothing wrong with the cluth, that was a 6000 euro work...
Does anyone have experience with this problem?
I have the same problem on my 360-F1. I don't have any oil leakage, the problem occurs in auto-mode, when using the paddles, when using sport mode. Tried a lot but notice no difference. The clutch seems OK, not slipping or whatsoever.
I now have my F1-system (pump, actuator, valves/solenoids) revised. I am anxious to see whether that solved it.
You say "...the gears have to much tolerance...": how did you find out and why is it too much (iow: what is not too much) ?
Biglen
Nice!
F1 hydraulics revision did not help though it revealed other issues (pump capacity was only 60%). So that subsystem is OK now.
THE Ferrari specialist in The Netherlands claims it is a known problem with the F1 box. If it shifts into neutral upon up-or down-shifting, it is 99.9% a worn-out clutch. I did notice a slipping clutch when breaking on the engine downhill (for what's that worth...). So I will get that revised now. And throwing in new belts, breakpads, sparks, thermostat (leftovers from previous owner) once that we are at it.
So with my 360F1, all the simple solutions that I came across on fora simply didn't solve it. My bad luck:frown2:
1 - 16 of 16 Posts
