1 - 6 of 6 Posts
When I bought my car a few months ago, every little electrical device in my car was working perfectly. The car itself had been standing for a while which was obvious because the tires had a little ding in it. But again, everything worked - AC, fans, interior lights, gauges, even the light in the ashtray worked. I drove the car for about 2000 km and nothing ever failed to work.
Recently I put my car into the shop because I wanted the entire suspension and steering overhauled. Also, they put in a Dinoplex conversion (voltage booster) which ferraripartsexchange send me instead of the electronic ignition conversion that I had originally ordered from them. Furthermore they exchanged the window washer pump for a new nonoriginal one.
After I picked up the car again I gradually realized that my entire electrical system is screwed up: The main beam sometimes works, high beam never. AC sometimes works. Heater fans and heated rear window don't work. The radiator cooling fans sometimes work (of course, same with AC, never when it's really hot and your standing in traffic...). The clock has stopped working completely. Even the new washer pump only sometimes works. Also, when I turn on the lights, all gauges go up 5mm in their reading, except the gas gauge which goes to completely full no matter how full the tank is.
I called them up and told them about this, and the response was that when a car was standing for a while and then you suddenly start using it again, devices will start to fail - because of that sudden usage...
I think this is major nonsense. First, nothing - absolutely nothing failed while I was driving the car before it got to the shop. Secondly, non of these failure came gradually, one after the other - they were all there after I picked up the car. It just took me a while to realize some of them.
All the fuses are new and fine and the fusebox and its surroundings look like they're in perfect shape. I doubt it's any of the relays since the problems are spread over too many circuits.
Does anybody have an idea what this might be..?
Thanks,
Howard
gave it some more thought out with the new in with the old unit . run car check voltage if the same check alts voltage regulators. new unit might have fried them. ive come across a lot of brand new junk out of box never opened. good luck
electrics
Its the dinoplex. I think they are secretly made by LUCAS, Prince of Darkness who supply all the crap in the old British cars. When I had the same problems, I went to a parts yard and bought a 65 amp Alternator and I have never looked back. The dinoplex sits there and makes a nice underhood ornament.
Even though mine is just an old 330GT 2+2 it was all but the last one in the run and so all the electrics are the same as the 365's.
When you make the switch, you go from a 3 wire system to a 2 wire one. It was a breeze. You need more volts and amps.
Sharkey
Discussion Starter · #6 ·
Thanks for your help, guys.
It finally turned out that the voltage regulators were gone. I had them replaced (at least for now) with Porsche units.
In the meantime I'm working on a solution with a proper Bosch alternator with internal regulators and more power.
1 - 6 of 6 Posts
