Doing my first change and had a couple of questions:
1) The parts manual talks about a lock for the pin that is punched out to release the spring that holds the pads. Mine does not have such locks - is this general? They seem from the illustration to be a type of collar.
2) The rear pads are retained with a spring. There is no obvious way to release the spring. Do you clamp the lower part to withdraw the lower pins from the caliper?
Tried to search the archives here but the forum does not seem to have a search function?
Any help appreciated
