1 - 1 of 1 Posts
I found this listing that should be of help. I can't guaranty the accuracy though:
89 328 GTS. I did find part numbers for the 86 328 GTS but I don't think they are the same I could be wrong.
Warm Up Regulator 0438140132
Fuel Pump 0580254947
Fuel Pump accumulator 0438170004
All of the Bosch part numbers are listed in the 308/328/Mondial Forum cross-over parts sticky thread at the top of the forum on page 4.
http://ecat-online.bosch.de/toc/code...tJavaVersion11
Here are the Bosch replacement parts # to avoid the f-car markup.
**80-82 308's & Mondial**
(in some cases old part # may be superceded, see your supplier for details)
Fuel Distrib- exchange - FD68X
Injectors - 0 437 502 047
Injector Seals - 3 430 210 606
Fuel Filter - Mondial - 71039 308's - 71011
Fuel Pump Mkt - 61975
Fuel Pump - 0 580 254 975
Air Flow Meter - 0 438 120 126
Aux. Air Valve - 0 280 140 129
Cold Start Valve - 0 280 170 401
Main Relay - Mondial- 0 332 204 001 308-0 332 019 151 & 0 332 204 101
Fuel Accumulator - 0 438 170 004
Warm Up Regulator - 0 438 140 083
Thermo Time Switch - 0 280 130 220
Vacum Limiter - 0 280 160 111
**83 - 85 308 & Mondial**
Fuel Distrib (exchange)- 83-85 308 - FD68X
Fuel Distrib " - 83 Mondial - FD68X
" " " 84-85 (3.2)Mondial - FD65X
Injectors (all) - 0 437 502 047
Fuel Filter - 308- 71011 Mond. - 71039
Fuel Pump Mkt. - (all) - 61975
Fuel Pump - (all) - 0 580 254 975
Air Flow Meter - (all) - 0 438 120 126
Aux. Air Valve - (all) - 0 280 140 129
Cold Start Valve - (all) - 0 280 170 401
Fuel Accumulator - (all) - 0 438 170 004
Warm Up Regulator - (all) - 0 438 140 083
Thermo Time Switch - (all) - 0 280 130 220
Vacum Limiter - (all) - 0 280 160 111
O2 Sensor w/connection - 83-85 308 - 13009
" " " 84-85 Mondial - 13009
Main Relays - *83-85 308* - 0 332 019 151 & 0 332 204 101
83-85 Mondial - 0 332 204 101
ON ALL MODELS SO EQUIPPED:
Frequency Valve - 0 280 150 300
Lambda Control Unit - 0 280 800 063
Pressure Damper - 0 280 161 019
Pressure Sensor - 0 280 101 003
Throttle Switch - 0 280 120 310
**82-84 - 512BBi**
Fuel Distrib - no part #
Fuel Filter - 71020 (2 req)
Fuel Pump Mkt.- 61947
Fuel Pump - 0 580 254 947
Air Flow Meter - 0 438 120 171
Aux. Air Valve - 0 280 140 104
Cold Start Valve - 0 280 170 412
Warm Up Regulator - 0 438 140 105
Main Relay - 0 332 204 001
1 - 1 of 1 Posts
