So about a month or so ago I was out for a drive and I went for a gear change (2nd to 3rd) and then got a slightly odd engine note and then WAY reduced power, but it was running, I pulled her over and the engine seems good, temps fine, oil pressure good, but just no power. At first I thought clutch, but just doesn't seem to be that, and now it runs a little odd, doesn't idle quite right and little bit of white smoke. There is no water in the oil, or vice versa. I did a compression test on all 8 and turned out very good, a minimum pressure of 150, and a max of 170. But something just isn't right. I wondering if I've blown a head gasket and it's just appearing in an odd form?? That or my only next guess is that I have a leak in the vacuum system somewhere and it's throwing the fuel and ignition timing all out of wack!! I don't know, and am wanting to hear any and all ideas from you all. Thanks - Nick
