did someone kept the post about Verdi changing belt in situi (removing tank) because the link of this post isnt good anymore and I would like to have the photos of it again.
thanks
nico
thanks
nico
It is not a question of cutting corners. It is a different, in this case easier, way of accomplishing the same task. In many ways it is better not to take the engine out of the car. This is why Ferrari designed the 360 so that the belts could be changed more easily without removing the engine.Ferrariby30orbust said:you would have to be nutz to attempt to cut corners like this when servicing your ferrari! If you cant afford to do it as ferrari designed it to be done, then go buy a corvette. Just an observation.![]()
