After having my distributor cap pitted, with greenish junk building up on the contacts and having cleaned it off for the 3rd and last time. The 3rd time It came back in 20 minutes and this issue would cause rough running; time to change the ingition parts.
So, I took out a second motgage and replaced cap, rotor and wires and the car is running fantastic with power right to redline. I did not change the extenders as they all were within spec when I tested them, but i still may change them anyway. Now after a day and 80 miles of spirited driving I will pull the plugs and have a look at them to see their color.
But after doing this I want to make sure the FI settings are in spec. The P.O. had the the fuel distributors rebuilt and the car idles a bit high - 1400 RPM. Just curious if anyone has adjusted the fuel injection system and what equipment is necessary to do this procedure. The car is running really great, but I want to make sure it is running it's best.
Should I just take it to someone who knows the cars or is it somthing a decent backyard mechanic can do? If David F was local I would drive it to him, but he is 4 hours away.
Thanks for any info you can share.
