Hello all,
Today I won a bit and lost a bit. Hopefully with a bit of elp from you fine folks, I can be certain that overall I won today.
First, I found out that Stabilizer 22 is made from relatively common industrial chemicals ( hint search the CAS #s - tradenames are even given ). So I am able to make my own when I run out.
Also found out that the R22 AC unit has already been converted to 134a. That was the good news.
As my climate control system periodically blanks out, I decided to clean the barried relays and fuses under the bonnet.
Here I discovered that one fuse was missing???
Also in the process I broke a wire to a relay. I soldered it back in but am not certain that it is connected.
Everything seems to work but I have never been able to be certain that the recirculate cabin air switch is doing anything. On other cars, the fan noise gets much loader. Maybe this has never worked.
I scanned a crude diagram and if anyone can tell me
1) what is the amperage of the fuse in F4 spot? I guessed at 3 A.
What does Relay 6 do ?
Any info would be appreciated.
Greg
Greg
