1 - 8 of 8 Posts
Does not my engine fire twice as often as a Porsche at 1,000 rpm?
:eek:
Ha...ha...a tricky question to say the least. Are both engines supposedly turning at 1000 rpms? If so then your 12 cylinder would have twice as many spark plugs fire as a Porsche 6 cylinder. But the rate of ignition for each cylinder of each engine would be the same.
:eek:
Yes... 12 Cyl - 6 Cyl both at 1000rpm yours fires twice as much
Discussion Starter · #6 ·
I just wanted to comfirm why my car is so smooth running.
12 cylinders is smooth
8)
Yes, 12 cylinders is much smoother than 4 or 6. Back in the '30s Cadillac had a V-16 engine. Smooth.
well, the Bugatti Veyron has a W16 cylinders engine
that should be smooth :roll:
1 - 8 of 8 Posts
