Checking further, you have a mechanical (cable-operated) clutch, so forget much of above. Things are simpler - if it doesn't disengage then most likely either the cable is snapped or has become dislodged from the pedal or clutch housing, or something has gone wrong at the release bearing. Again, pressing the pedal should be moving the release arm at the clutch housing.
