1 - 10 of 10 Posts
What you mean is she will not select reverse, no? Does the little lever that selects reverse still need to be lifted to get into reverse? Hill Engineering/Ricambi sell a replacement lever that will not break if yours is wonky.
Thanks for the Hill Eng. link. I assume the RL-03 lever is the solution. Any comments on DIY installation?
No, but it is pretty simple.
One trick for longevity: do not select 1st gear with the tiny lever, use the paddles instead.
Discussion Starter #5
Thanks for the info. I have the RL-03 lever ordered from Ricambi and pulled the box out. Noticed the 4 screws were slightly scarred, which told me that it had been pulled at least once before. Upon disassembly noticed that the 'nipples' were sheared off, one of the 4 little discs missing, and the black plastic 'dooflicky' or whatever it's called loose in the box. Further thoughts?
No, sounds like you found the problem.
Discussion Starter #7
Have placed the little black dooflicky (what's it called?) back in its slot, tho' unsure of its orientation, and tomorrow reassemble the box for a test to see if anything works.
Discussion Starter #8
Reassembled the box, carefully replacing the black plastic piece in its slot...nothing. Took it all apart and reversed the piece of.....and reassembled for test. Nothing, no indicator lights, no F or R. Any comments welcomed.
Discussion Starter #9
Able to engage forward with paddle and drove to MPI in Neenah. The box cannot be disconnected and removed w/o partial console disassembly.
Discussion Starter #10
Guys at MPI took the box apart, cleaned and reinserted the "dooflicky" and now reverse OK. A mystery.
Next, any thoughts on the 612 driver's side window switch/ module?
1 - 10 of 10 Posts
