Yesterday, as I do most weeks during winter aly-up, I started the 550 up...It started 1st time as usual went through it's engine check routine, Said "OK"...
But once warmed thro' for about 15 minutes I took it around the block, and noticed the Oil Pressure gauge moving in sync with the revs as I pressed the accelerator....at 3,500 rpm it was mid point on the gauge were it normally stays, but at 5,000 rpm it was approaching 140 lbs/In, So I limped home....Does anyone have a diagnosis?
I checked the Oil resvoir, It was on Max.
Argento
Argento
