1 - 12 of 12 Posts
Pictures from Vulcan F-40's, 512TR Cambelt Service.
Discussion Starter #2
Set 2
Set 3
Discussion Starter #4
Set 4
Discussion Starter #5
Set 5
Wow! Beautiful car. I also love the landscaped yard where the pictures were taken. Hopefully my yard will come out as nice. (right now it is all snow covered dirt with a bulldozer sitting in the middle of it). The engine work looks immaculate. Money well spent. Enjoy!
The engine looks immaculate! It must be from all the Shell gas;) The yard looks wonderful! Oh yea and the 512TR looks the best:D :D
Chris
what a privilege to see the engine that way, really! thanks for sharing and congratulations, amazing car (cars, actually) you have
Dear Comrade Boxer,
Thank you for going to such trouble in placing the images on my behalf.
The full story of this strip-down is that the cam belt service was due and I was aware that there was a slight leak from one of the camshaft oil seals. However, upon removal of the engine it soon became apparent that there were also very minor oil leaks from the cam cover gaskets. Yet another small leak was spotted that emanated from one of the cylinder head gaskets. Then a negligible coolant leak was observed from the rear of the water pump area. The nett result, as may be readily observed from the images was a major disassembly of the engine/transmission unit. However, all is now well. And whilst none of the work was by any means essential, at least I now have the comfort that everything is nicely oil and water-tight.
Thank you again.
With kind regards,
Vulcan
Dear Comrade Vulcan F-40,
Your 512 TR looks superb. If I'm honest the TR series cars have been largely overlooked by me in favor of the earlier Boxers and later front engined V12's, but over the last few weeks I have taken more interest in the TR's, especially the later Testarossa's and the 512TR. I am also starting to like the shape and styling, even the side strakes and covered rear lights. It is quite likely that my next Ferrari purchase (12-18 months:( ) will be a TR or a 550M.
I would be very keen to hear about your ownership experience of such a fine motorcar.
Kind regards
Archie
Discussion Starter #11
The workmanship is superb. A very wise decision to get everything taken care of while the engine was already out of the car. I had a not insignificant bill on a 365 BB a few years ago when the engine needed to be pulled to fix a problem with the water pump. While it was out, we did the belts, gaskets, and everything else we could think of just to avoid any more near term surprises.
Looking at the block again, magnificant engine.
Kind regards
Archie
Dear Comrade Archiegibbs,
Regretfully, there is little to say with regard to the 'ownership experience' for there are no tales of woe to report or any other matter that has been in any way disconcerting. The recent work was of course complex, but was not crucial and the car would have run very happily for a long period - many years propably, had I chosen to ignore the slight oil leaks.
The TR is not inordinately complex; at least, not in the way that more modern cars are. It is a terribly robust machine and the engineering integrity is such that its durability could provide an indefinite lifespan. Apart from normal servicing and the recent work that was performed, absolutely nothing has ever gone wrong - nothing at all.
I feel quite confident that should someone acquire a well maintained TR I am certain that they too would be very happy with their acquisition. And unless they were to be extremely unfortunate the cost of ownership need not be inordinately large. And the sound of the flat twelve once it traverses four thousand rev's is absolutely blood curdling. No doubt Boxer will attest to this as he also once owned such a device.
My only caveat would be that one should make absolutely certain that any car that one may consider should be thoroughly checked by a specialist. One needs to be mindful that the TR became available from 1992 until 1994. Accordingly, the youngest will be fourteen years old, and if it has had a hard life without timely maintenance then by this time it will begin to show signs of a gentle state of decay. So, if you are able find a very good example of a TR then I would say that it could be well worth considering. No doubt all of the aforegoing is applicable to a Testarossa. But, I think it is generally accepted by the aficionado's that the 512TR is a more refined motor car.
With kind regards,
Vulcan
1 - 12 of 12 Posts
