Hay Mike, I have a Scud primarily used on track. I've used many combinations.
No offense to Stef but I run P-zero slicks only. I have the same Penske coilovers developed for the 430 gt cars, 4x the spring rate of the stock Scud. On very hot days it is possible to overheat the F1 diff but almost never happens and is fine after cooling down- happened 2x in 4 years. 1:
[email protected] watkins glen
The real trick is add some grip without overwhelming the very soft springs & dampen rates. These cars are amazing because they are balanced. Sport cups are my recommendation. For wheels i would goto 458 challenge car widths 9x19F 11x19R? Check me on that. You can keep the same size tires as stock on the wider wheels. Forgeline is my preferred, very light & strong, bbs is second- multi-piece so you need a repectable shop to change tires without messing up the seals.
Great car, its a beast, enjoy it.
