Yes I believe this could be done. The 360s wheels are 1inch larger so you would have to get a smaller profile tire to match your current F355's total diameter. I don't remember if the F355 has the sensitve anti-spin software that the 360 has. If it does changing the weight and diameter may cause this to act up and you'll have the warning light on your dash lit up.
I have heard that it can be done but involves a ton of work to recalibrate various systems to accomodate the larger tire. Suggest you check with a local Ferrari specialist or dealer.
No they're both 18". However the F355 use 225/18 fronts while the 360 use 215/18 fronts. But that doesn't matter, the 225 can fit the 360 front rims. The stud holes are identical.
wow the 360 wheels look amazing on the 355, i think they also give the car a slightly more modern look.
so will the extra distance the wheels stick out actually make them protrude from the wheel arch or will they be within a tollerable limit which would be equivalent to putting the official 355 wheel spacers on the car?
Related Threads
Ferrari Life Forum
325.1K posts
28.1K members
Since 2002
A forum community dedicated to Ferrari owners and enthusiasts. Come join the discussion about performance, build specs, production numbers, modifications, classifieds, reviews, troubleshooting, maintenance, and more!
