1 - 2 of 2 Posts
Hello... I have now my 360 Spider since almost one year and I'm still searching the perfect adjustment for my driver seat. I'm 6.1ft (183 cm) and if I put the back too straight I am seating too high. If I lay down a bit more, I do not have enough armlength.
Also, what is the use of the lombair adjustment and the seat width adjustment ?
Do you know some rules for the perfect seat setting cf. correct arm and leg positions ? The knees must be folded a bit I guess and they told me that you should be able to put your wrists on the steering wheel...
Thanks,
Didier.
· Administrator
When your driving around a turn at a high speed this will support your body from sliding on the leather. Image going around a turn with sedan seats and your butt is going to end up in the passenger seat when you are taking a left turn at say 80+ mph. Some people are wider than others so it is nice to adjust this.
1 - 2 of 2 Posts
