I just had a call from a friend with a 360 F1. He's on a road trip and apparent shut the car off while being in reverse backing into a parking spot. Car will not restart. Anyone have any suggestions? I thought maybe disconnecting the battery would cause a re-set of the on board computer and maybe that would help. Suggestions would be appreciated.
You can't start the car in reverse. Turn on the car, pull both paddels to put it into neutral, turn off key and then start like normal.
360 F1 Tranny problem
Well, thanks for the response. Sadly, my buddy had to flatbed the car from Redding, Calif back to LA and stuck it in the shop for the repair job. Quite an expensive mistake he made. But I would imagine that more than a few people have probably made the same mistake. I will share your solution with him just in case he has a brain fart and does it again!!
